dedicate Posted May 25, 2008 Posted May 25, 2008 Budget under 2k I have a stereo setup at the moment for music. I don't watch that many movies. Onkyo 605 Focal 836V What is a good subwoofer? I was looking at the matching sub SW800, what else should I consider? Should the speaker brand match?
norpus Posted May 25, 2008 Posted May 25, 2008 Budget under 2kI have a stereo setup at the moment for music. I don't watch that many movies. Onkyo 605 Focal 836V What is a good subwoofer? I was looking at the matching sub SW800, what else should I consider? Should the speaker brand match? Sub brand does NOT need to match other speakers. For music only and <$2K, get a quality sealed sub IMO. Locally made will get you best bang for buck
Chui2 Posted May 25, 2008 Posted May 25, 2008 Sub brand does NOT need to match other speakers. For music only and <$2K, get a quality sealed sub IMO. Locally made will get you best bang for buck Not locally made, but sealed and under $2K SVS SB12+. http://www.deephzaudio.com/Plus%20Series%20(Subs).htm
50mxe20 Posted May 25, 2008 Posted May 25, 2008 Subwoofer How Do You Demo A Subwoofer? Excellent Comparo Data - Subwoofer Shootout Recomendation for HT subwoofer Best Ht Subwoofer < 2k -- Need Help For Sw Upgrade Subwoofer Rveiews Which Subwoofer for $1k-$2k?
betty boop Posted May 26, 2008 Posted May 26, 2008 Sub brand does NOT need to match other speakers. For music only and <$2K, get a quality sealed sub IMO. Locally made will get you best bang for buck for under $2k well rrp of $1799 the legend kurlo is actually bloody good ! for both music and ht. it is a sealed design, well built and finished and being locally made really good value http://www.legendspeakers.com.au/products/kurlo.html http://www.carltonaudiovisual.com.au/?q=node/view/680
Gutty Posted May 26, 2008 Posted May 26, 2008 While i agree sub brand does not need to match your mains, i did end up with the Focal SW800 to go with my 826's, for three reasons. 1, i got a ripper deal on it while buying my 826's and CC 800. 2, it visually matches the fronts, i like this as does my better half. 3, it's not a bad sub for it's size.(only 11" driver) and really didn't want anything huge where i'm currently living. And FWIW i'm more than happy with my purchase.
dedicate Posted May 26, 2008 Author Posted May 26, 2008 While i agree sub brand does not need to match your mains, i did end up with the Focal SW800 to go with my 826's, for three reasons.1, i got a ripper deal on it while buying my 826's and CC 800. 2, it visually matches the fronts, i like this as does my better half. 3, it's not a bad sub for it's size.(only 11" driver) and really didn't want anything huge where i'm currently living. And FWIW i'm more than happy with my purchase. SW800 will cost me 1.3k to get. The best deal i got on the 826V was 2400
dedicate Posted May 26, 2008 Author Posted May 26, 2008 Has anyone used a Dick Smith Subwoofer before? lol Under $200
trekker76 Posted May 26, 2008 Posted May 26, 2008 i got the SVS pb12 plus/2 ... love it.. my windows were shaking at 1/2 volume.. spec below
bensl Posted July 8, 2008 Posted July 8, 2008 just wondering if you ended up buying a sub. i have a similar setup (826's & yam 1800) and am looking for a sub as well. i was hoping to get one nearer to the $1000 mark.
