Greetings All,
Putting together a listening list for a friend of a 5.1 setup for around $4-5k. I have provided him with a list of sub/sat packages but he would prefer floorstanding fronts.
So far I have come up with the following options - I have included one Australian speaker, one US/Canadian and one European. Just to give him a good cross section of what is out there.
Prices listed are RRP...I have assumed that when packaged the price will come down.
Australian Speaker
Krix
Setup - Phoenix(fronts), Equinox(rears), Centrix(centre), Seismix Mk 3(sub)
Price - $3600 approx
US/Canadian Speaker
Paradigm
Setup - Monitor 7(fronts), ADP190(rears), CC290(centre), DSP-3200(sub)
Price - $4500 approx
(Note: Spoke with Steve at Eastwood Hifi.. and he advised to avoid the PDR-10 sub...so I wouldn't need to upgrade my mains. He also said to go with the Yamaha 863 amp as it's better value than the 1800....all up he could package the whole thing for $4700)
European Speaker
Focal JMLabs
Setup - 714V(fronts), 705V(rears), CC700V(centre), SW700V or Velodyne CHT-10R
Price - $3800 approx
As for the amp what do people suggest (keep in mind the budget)..... Was thinking an amp around the 1500-1800 mark would do the trick. Maybe an Integra 7.8 or on the more expensive side the Denon 2808. Would certain amps also be better for certain speakers ?
Bear in mind he wants an amp with 3-4 HDMI and must have Dolby True HD and DTS HD Master Audio
  • Replies 55
  • Created
  • Last Reply
Top Posters In This Topic
Greetings All,
Australian Speaker
Krix
US/Canadian Speaker
Paradigm
European Speaker
Focal JMLabs
Is the 4-5K budget for speakers only or is it the price for the whole package ?
For the whole package... as you can see from the quote from eastwood it is doable.. and those speaker prices are rrp.
So I am sure money can be shaved... Nearly all Hi-Fi places I have spoken too have offered me at least a 15% discount
Edited by Katarn
I like the Focal package, but maybe get the next floorstanders up, and go for a Yamaha amp as they tend to go well with the focals.
Yea, I felt there was a bigger step between the 714S and the 716S than between the 716S and the next ones up.
As the others have already said I would spend the extra and get the 716V's. I had them as my floorstanders and they are very good for the price
Focal is definitely a good option. Monitor Audio RS6, matching centre RS-LCR, and Bronz surround speaker and SVS sub are also worthy of your consideration.
Edited by jliang70
Australian Speaker
Krix
US/Canadian Speaker
I have been considering the Krix setup. The price I've been quoted is a lot higher then $3600. Where did you get that quote from.
I'm in Qld.
Regards
Clive
Keep an eye out for superceded models.
I'd also recommend Focal. Managed to grab the 716S, CC700, 706S and Velodyne CHT-12R, all for $2,930. All new too in case your wondering.
Superceded models of course on runout. Grabbed a new Marantz SR4001 Amp for $500 too.
Very happy for the money I paid. My first home theatre system.
Wouldn't mind a Paradigm S6 system down the track though.......mmm.
Cheers,
Nikos
Interesting price. Was considering selling mine and wondering what a good price would be.
Okay I will take a listen to the 716Vs... as for the Yammy amp.. my main issue with this is that many of the hi-fi stores in Melbourne don't stock them.
They are either pushing Integra or Denon. I can get the yammy amp from JB i guess.. but i'm sure that will lessen our bargaining power on the speakers..
Hmm I've heard of Monitor Audio but haven't managed to find a retailer who stocks them in Melbourne.
With the Focal speakers i have chosen what is a good choice from an AMP(haven't managed to find a Focal one in the same range).. would the Velodyne I suggest match okay or is there something else better ?
As for the Krix - yes that was retail price both in Melbourne and Perth. Sounds like QLD stores are taking advantage of "extra transport costs"
Carlton Audio Visual stocks Monitor Audio speakers.
Ahh excellent.. good to know thanks :)
Hmm seems like a trip into the City needs to be planned. Hit Clef Hi Fi for Krix and then onto CAV in Carlton for the Monitor Audio and then E-Home Solutions in Fitzroy for the Focals.
Krix and Focal are light years apart in sound. IMHO. Not sure how you could be comparing them.
Is your question an amp one or a SW one?
I stuck with the Focal SW. I reckon it's pretty good and matches with the other Focals well.
Any good quality amp will drive the Focals.
I'd be listening to them and deciding if you can hear a difference and then going with the one you like from a sound point of view.
Greetings All,
Carlton Audio Visual have Monitor audio http://www.carltonaudiovisual.com.au/?q=node/view/66 in Melbourne.
whoops beaten by jilang there.
I would add that its imperative that your friend listen to your list of speakers for himself.All of the brands you have listed are well worth a listen and differences between them can be subtle at times, I would recommend taking the same dvd's and cd's to auditions so at least that part of the process is a constant.
Other factors will be beyond your control such as room acoustics, setup and different sources driving the speakers.
1 mans meat is another mans poison ;)
Edited by cooksta
Good analogy.
I agree.
If you are in the city, you can also go to Audiolifestyle located at 214 Brunswick Street, Fitzroy. (http://www.audiolifestyle.com.au). They stock Focal, Mission, Elac, Kef and some other brands of speakers. I think you got mixed up with E-home and Audiolifestyle. E-home is at Dandy Road, Carnegie.
Hi Lyle.
Actually it was both an amp and Subwoofer question :).. but thanks for the advice :)
and yeah jliang I got mixed up *blush*
And yes I'll be taking my friend listening.. his money after all :)
And Lyle I mainly included the Krix to be on the lower side of the 4-5k budget
Hi Lyle.
Actually it was both an amp and Subwoofer question :) .. but thanks for the advice :)
Remember my advice is only an 'opinion/personal preference'.
There are many people here who love Krix. I tried too but fell 'out of love'.
The love of my life is a much cleaner sound with less bass that I felt the Focals and possibly the Paradigms give one.
Just like I felt Denon amps were warmer than Yamaha.
But again sound is such a personal thing I don't believe anyone can give advice. Only guidelnes.
Taking your friend is an excellent idea. And going together is good too because you can bounce ideas off each other.
Some (but not all) salesmen are very good too, especially in specialist shops.
Taking music and movie scenes that your familiar with is also a very 'sound' idea.
The only problem is that auditioning does take a lot of time.
Have fun!
Have fun!
Yep I realise that... I'm probably with you on the preferring clean sound over bass. But I will see what my friend thinks.. he may end up just wanting a good bang for buck system that will give him lots of boom in movies.
Yeah I know I hated going into AV stores at the start by myself armed with very little knowledge....gives sales people that chance to spin tall tales about certain products.
And yep already got our seperate libraries selected...got some slight differences in tastes in movies and music. So I'm taking along stuff that may test the systems in different ways.
As for amps I guess at the end of the day brand is somewhat irrelevant.. and really just comes down to features and the sound they provide versus the price point you can get one at.
Same with music on CDs. The only time I use bass boost is in the car.
Otherwise most of what I listen to, I listen to flat. As it is on the CD.
I thought I could tell the difference, even at my age. But in the end maybe I got swayed by the 'Japanese' components. :)
(And the smooth talking salesman :blush: )
Very good point.
:lol:
Try the Ikon 6s and 7s also if you prefer a clean sound over bass (not they don't have bass but their tone is towards the leaner side and very transparent)
