I am currently on cable foxtel and will be moving in a weeks time to a house that only has satellite so I was just wondering what the differences were between them.
Also I am planning on getting foxtel hd when it comes out so am I still able to get that.
Edited by skyline7
Different decoder box is the difference (apart from a satellite dish of course) and you may not get FTA channels off satellite yet in Brisbane.
Yes, you will be able to get HD off satellite, when it's available.
Thanks mtv :)
When you say I need a different decoder box does that mean I will lose my recordings.
Yes, they'll swap your cable iQ for a sat iQ.
You will notice that Satellite is quite a bit slower than cable when you change channels and use the menus, programme guides etc.
If you are going to be getting a standard box rather than an IQ, try and fight them for the Pace 420 box which is the better of the ones Foxtel have in terms of speed and picture quality.
I haven't really noticed any speed difference between cable and sat with menus and the likes. I'm only using iQ's though
Thats not true at all. The speed of channel changes and menus was nothing to do with the difference between cable and satellite but FOXTEL's use of the rebirthed legacy 720 units on satellite - which, by their nature, had slow processors hence they were slow to use.
A 420 on cable and satellite shows no speed difference at all.
Thanks Guys
I know 2 people with Satellite and I have cable, there ones were slower and come to think of it they had UEC boxes where as I have a Pace so that probably explains it also.
I will now go and wash my mouth out with soap !
