I bought a pair of Sennheiser wireless headphones and that is where the problems starts. The transmitter, for some reason, has some kind of smart electrionics in it that turns the transmiter off when it can not detect a signal from the TV. The problem with the TV audio out on the back of the TV is that the signal strength seems so low that the headphone transmitter doesn't think there is a signal at all and so turns off - very very annoying!
I have tested the TV output by plugging it into a stereo system and found that the TV must be turned well up and the stereo must be turned well up also to be able to get a decent volume out.
Is there any way to increase the output of the Variable Audio Output through some menu. I have read the manual and can not find one - perhaps its in the service menu or something???????
Any help would be appreciated.
