garyinoz Posted April 2, 2007 Share Posted April 2, 2007 Going to try and roll a couple of questions up here. I have a Panasonic EX75 DVD recorder which I have brought over from the UK. Firstly can I get anything to convert it to pickup tv reception here on digital, someone had suggested that it would be possible to some how fix on a SD module? Anyone no more about this? Secondly, I need to have it converted to region free, I could take it panasonic and have them do it but if It can be done in a shop somewhere that would be great. I live in St Leonards, Sydney. Thirdly, when I buy my new LCD screen and connect it with my dvd recorder via HDMI what else do I need to consider, I have the DVD recorder connected via digital to my surround amp. My DVD recorder obviously has scart and component. I have a foxtel box which also connects via component. Should I connect the foxtel via component directly to my dvd recorder, and connect this to the tv via HDMI/Component? Hope someone can help me out here and answer some or all of these. Thanks Gary Link to comment Share on other sites More sharing options...
alanh Posted April 2, 2007 Share Posted April 2, 2007 Gary, If there is recording inputs then buy a set top box and plug it in. Preferably in this order of quality; DVI, Component y, Cr, Cb SCART, Svideo, composite PAL. The only disadvantage of this arrangement is that it will not change channel under timer control unless the STB will. AlanH Link to comment Share on other sites More sharing options...
