Binxx Posted March 26, 2007 Share Posted March 26, 2007 Hi all, as you know the Sony KVHR series does not have HDMI input. In light of this, can someone suggest the appropriate cable please. I have been led to believe that the PS3 comes with the component cable, would that be right and if so is it a decent quality? If not, is there a RGBHV cable available from the PS3 to the KVHR and would that be a significant improvement? I tried to google the available outputs from the PS3 but could not find the exact details Could someone post their experiences with the PS3 and the KVHR please. Thanks Link to comment Share on other sites More sharing options...
AndrewW Posted March 26, 2007 Share Posted March 26, 2007 PS3 only comes with a composite cable. Nice work Sony. You can pick up a PS3 component cable for $20 from Kmart. Andrew. Link to comment Share on other sites More sharing options...
DonR1503559521 Posted March 27, 2007 Share Posted March 27, 2007 Hi all, as you know the Sony KVHR series does not have HDMI input. In light of this, can someone suggest the appropriate cable please. I have been led to believe that the PS3 comes with the component cable, would that be right and if so is it a decent quality? If not, is there a RGBHV cable available from the PS3 to the KVHR and would that be a significant improvement? I tried to google the available outputs from the PS3 but could not find the exact details Could someone post their experiences with the PS3 and the KVHR please. Thanks Binxx, I have the KVHX and use the Sony multiav component cable and set the output to 720 as it matches my projector res (HDMI/DVI). It looks really nice. DonR Link to comment Share on other sites More sharing options...
THX1979 Posted March 27, 2007 Share Posted March 27, 2007 tell me how Blu Ray movies look on the KVHR!!! Link to comment Share on other sites More sharing options...
DonR1503559521 Posted March 27, 2007 Share Posted March 27, 2007 I purchased the HX over the HR because at 32" it wasn't worth it as this telly is my everyday watching set. Ask me how the difference compares across 85" Link to comment Share on other sites More sharing options...
