Hi guys,
Does anyone out there have a Soniq TV which they managed to get a different manufacturers remote to work with? I specifically need the remote codes to put into my LG remote (from my STB) which will enable it to control the Soniq TV. For some reason Soniq isn't listed in the remote codes table in the LG manual! :blink:
Thanks in advance for any advice or info anyone can provide!
Hi guys,
Surely someone has been able to set up their Soniq TV with a non Soniq remote control??
Unfortunately this one doesn't have such a function. :blink: You have to manually put in the code to try it. I suppose I could brute force it... Only 1000 possible combinations, guess thats not TOO bad.
