HDSTC Posted March 2, 2007 Posted March 2, 2007 Hoping some one can help with the following, I have an NEC VM5W plasma , Im getting a ghosting effect not sure if this solarization as Im not sure what that is, so if theres a description available that would be a start, would having the screen calibrated help, if so who is the best person in Melb to do so, any contact number appreciated , Thanks
Guest JimboTHX1138 Posted March 3, 2007 Posted March 3, 2007 http://asia.cnet.com/reviews/home_av/other...44c-39000544q-1 Hope this helps
HDSTC Posted March 3, 2007 Author Posted March 3, 2007 http://asia.cnet.com/reviews/home_av/other...44c-39000544q-1Hope this helps Thanks for that , read the section on Solarization and thats sounds like the problem I have, is there any way to fix it, will having the screen calibrated help. ?
wheelz Posted March 6, 2007 Posted March 6, 2007 HDSTC contact arron ,he's in melb and can calibrate your plasma.He has done many members panels and every one raves about the improvement.(search forum for the many threads on "calibrate") http://www.avicalaustralia.com.au/contact.htm
