Brett1 Posted February 9, 2007 Share Posted February 9, 2007 I am looking at purchasing two new Nebula-electronics DigiTV PCI cards, however the current one I have has issues when the temperature in the house gets above 25˚C the tuner looses total signal. Once this happens I have to shut the PC down and let it cool down. This has been going on for about 2 years, through winter the card works fine I only have issues on hot days. Has anyone else experienced an issue like this or am I just unlucky? Cheers Link to comment Share on other sites More sharing options...
murrayt Posted February 9, 2007 Share Posted February 9, 2007 Brett1 Possibly unlucky, or perhaps your PC Case/Cooling needs some review. The heat generated by the CPU, motherboard and disk drives is the main problem generally. That can excessively heat the other components such as a PCI card. If the case/cooling is fine then you may just be unlucky. The electronic components of cards from all manufacturers/suppliers are capable of failing. Link to comment Share on other sites More sharing options...
HyperReality Posted February 9, 2007 Share Posted February 9, 2007 Please contact us directly (support@hyperreality.com.au), as I'm sure there is something we can do to help resolve the problem or some advice we can provide. Link to comment Share on other sites More sharing options...
