IGNORED
Modified Camera Jpeg Pic's Won't Display Using Flash Drive
.........It may be the wrong thread but I need help from pc guru's
..... I hoping some one can help here.....
.....Now I'm not the best photographer
.....so my partner & I used photo-shop 6 to crop & reset the colour balance & exposure & saved the 2 meg jpeg files to a memory stick as well as an sd card & my plasma can either read sd cards or usb drives & I was presented with the thumb nails of the pic's on the plasma but that was as far it it would go :blink: ( these ports do play un-modified pic's dirrectly from the camera cards ok)
......My partner then stirred me up saying why do we have these toy's if they don't work & why does it always take so long & walked out of the room muttering things at me.... Heh Heh....
....not to worry so mmmm I then thried the pic viewer on my hd teac stb via flash drive & it wouldn't even respond to the jpegs
......so what is photo shop doing to these files or have I stripped some info from the pic's that is needed :D
......I then burnt the pic's to a cd & it worked fine via my pic viewer on the domestic dvd player connected to the plasma..mmmm..but when I used xp to do this a splash screen asked me do you want to modify these file's so the are usable on domestic eguiptment ( I can't remember the actual pgm mod that was mentioned as I'm at work but there was one)
*****Edit...I've just read my post maybe I should copy all the contents of the cd to a usb flash drive to see if the pic's now work as it did create some other folders but I'm yet to try this method.....mmmm*****
.....What's happening here & does any one know or has any one seen this before
..is there a fix for this so I can use memory cards or sticks to view my modified pic's
.......................... :P --ThisIsAllToMuchFun-- :P ............
..thanx in advance for any new info
Kim
Perhaps 2mb files are too much for the plasma to read quickly from the card slots? What size are the original photos?
......thanx for the reply Mcrackn :P
....... but my partners 10meg a pixel camera produces 2 meg jpeg files of this size normally & they load quickly
..maybe by saving just the jpegs to a memory device I'm missing some data files file that are normally present
... (from memory & I'm guessing at this as I'm @ work at the moment) ......if you look at the folders created by the camera in a sd card there are 2 root folders & inside one of the 2 root folders there is another folder & then your jpeg pic's
...... :blink: Kim :D ....
