R34 Posted January 26, 2007 Share Posted January 26, 2007 Hi all I'm new here so go easy on me OK I have a Panasonic AE700E projector that I've been extremely happy with. Just recently I've noticed a purple blue patch of colour in a part of the picture? Is this a sign of the lamp about to fail? It's showing 3750 or so hours run time so I have nothing to complain about I guess. If I need a new lamp where is the best place? I've found this company does anyone have any feedback on them? http://www.smartimports.net/proddetail.php...CFSnKggodKVRfRQ Cheers Chris Link to comment Share on other sites More sharing options...
The_Preacher1973 Posted January 26, 2007 Share Posted January 26, 2007 Hi allI'm new here so go easy on me OK I have a Panasonic AE700E projector that I've been extremely happy with. Just recently I've noticed a purple blue patch of colour in a part of the picture? Is this a sign of the lamp about to fail? It's showing 3750 or so hours run time so I have nothing to complain about I guess. If I need a new lamp where is the best place? I've found this company does anyone have any feedback on them? http://www.smartimports.net/proddetail.php...CFSnKggodKVRfRQ Cheers Chris Sounds like bad news I'm afraid. From the description it's more likely to be an internal failure of the PJ such as the polariser or LCD panels degrading rather than a bulb failure. That will likely cost more to repair than the PJ's worth. Take it into a service centre and get them to look at it before buying a bulb. Link to comment Share on other sites More sharing options...
R34 Posted January 26, 2007 Author Share Posted January 26, 2007 Ouch OK I'll talk to a service agent I was about to order a globe so thanks for the advice Link to comment Share on other sites More sharing options...
