tom01 Posted October 15, 2004 Posted October 15, 2004 Hi: I have done a search and couldn't find and answer to my quiry so... Having just purchased this unit I connected it, and although I can see the vision output, I cannot find out how to display the menu or anything on the screen (now & next etc). Pushing the MENU on the unit or on the remote does nothing. Is it 'locked' or am I just missing something. I can change channels, and MUTE but that is about it... Any advise is welcome ~ thanks - tom
tom01 Posted October 15, 2004 Author Posted October 15, 2004 Update: It seems that when using the S-Video or composite outputs, only when the unit is selected to 576i will the menus be displayed - other selections will show vision only. -tom
ChrisM Posted October 15, 2004 Posted October 15, 2004 When you select 576i the menu will be displayed on the SD outputs. When HD is selected, i.e. 576p 720p or 1080i, the menu is displayed only HD output. I think this is a good thing. You can record the SD output on VHS, etc., without recording the on screen display while you are watching HD. As you have purchased an HD box, I'm unsure as to why you've connected it with s'video or composite to your display?
tom01 Posted October 15, 2004 Author Posted October 15, 2004 Thanks ChrisM - yes that is what I figured out too - eventually. The reason for using these outputs - no HD display---yet. Regards tom
