WITHDRAWN OR RELISTED: Price Drop $$$ Ambience audio Valve Preamplifier dual.
Item: Ambience preamplifier
Price: $700.00 ONO.  $600
Item Condition: good for it's age works fantastic
Reason for selling: To many preamplifiers
Extra Info:
You can try it on your system and if your not happy will refund money in full as long as you bring it back same way.
Very sweet sounding transparent pre. Simple design makes a better preamplifier.  Also Tony Moore from ambience speakers is the agent of the preamplifier and has the schematic and can repair if something goes wrong.
It works perfect. No work of a lie the preamplifier punches way above a lot of preamplifier I've heard.
Pictures:
Ambience audio Valve Preamplifier.
Two box unit. It has a solid stage power supply with a second box with dual volume control using 2x 12AU7 tubes. It's a very nice sounding unit more on the warm side. It's very transparent due to the design.
The unit has two inputs 1 pair of inputs and 1 pair  of out put... RCA connections Simply design always makes good sounding preamplifiers.
unnamed-1-1.thumb.jpg.6629a6eeca32a4d306c3a1fd3ce726a4.jpgunnamed-2.thumb.jpg.bb5efa321df47534aa0aefeba00ff5af.jpgunnamed-2-1.thumb.jpg.f883de4b7b49feab110ae5d5601f502a.jpg
Edited by audiohifiaudio
Hi
I'd like to try the Ambience in my system, but don't have a power amp at the moment. Would you have any recommendations for one? My speakers are Sonus Faber Concertos.
  • 1 month later...
This item has been withdrawn from sale or relisted.
