Goodaye all
Now l have  got my Marantz system running as it should l need some advice on adjusting the crossovers on the Marantz DS 920 speakers.
You can adjust tweeter and midrange via 2 pots on the front.
Every setting from source to speaker is set in the nuetral position.
So how should l treat the speaker adjustments?
regards Bruce
I would start by playing a series of test tones to ensure both the best room set-up and best speaker adjustment for your own typical listening volume. Test tones are available on LP, CD and internet. The Fletcher-Munson equal loudness contour is also useful reading.
Then adjust further for your music and preferences.
Greg
Edited by GregWormald
Greg
Thanks
regards Bruce
