Item: Elektra Valve Pre Amplifier
Price: $2700.00 (Plus Shipping)
Item Condition: Like new (1 year old, 15 hours use)
Reason for selling: Cashflow
Extra Info:
It's the latest version and is an amazing product, beating other products that cost many times more, it also has home theatre bypass.
Pictures:
Edited by MouldyCrumpet
  • Like 4
Guest m_james
Why does it say "do not remove cover or any screws"? How do they expect you to change the tubes?
If it is like their so called "up-gradable" multi channel amps then you have to send back to manufacturer, crazy.
8 minutes ago, hotJ said:
tube rolling?
Those that have tried have ended up back with the factory ones, if it ain't broke, don't fix it.
Not crazy, anybody that opens up an electrical product, other than an authorised technician, will void a warranty. Arthur doesn't need technicians as he builds and designs them, and they rarely fail. I've had new tubes put in my pre but it is the previous model and several years old. It could not afford a new one so bought used.
What type tubes does this preamp use exactly and what tubes are supplied with it?
I wonder why "those that have tried have ended up back with factory ones"?
What tubes does this preamp use specifically?   I have never heard a tube preamp whose performance has not improved using premium tubes so this must be supplied with excellent tubes to start with I assume?
Ask our glorious leader @Marc. I believe he tried. Can't remember the type but mine cost around $200 to replace. I just wanted more of the same.
Thanks Neil,
You mean $200 per tube or $200 all up for all tubes?
I can't remember what is standard but I tried all sorts of weird and wonderful. As mentioned in another thread I ended up right back where I started.
As for not being improved upon factory - that's because these are not mass produced, and Arthur apart from having great ears, cares for nothing more than the best sound he can get from his products.
elektro harmonix 6922 if I remember. my arc phono pre uses the same brand as arc does on all their product and have for decades... they arent super expensive valves either. jay car used to sell them at one stage :D saw them on the shelf behind the front counter  hehe
given a pre amp, I doubt will ever need to replace em either. unless failed or something. which is possible....
why does he put a warning on the back probably to cover off on those who open it up not understanding they can electrocute themselves ! and that there is nothing in there for your average folk to be playing around with. its not unusual to have warnings to not open up on stuff with 230V power supplies inside...
Beautiful sounding pre. Yes as others have said, stick with the original tubes.:)
Updated link, inserted the wrong one...ops..
Edited by Sirmorebeer
Inserted incorrect link. Updated now.
hi
does anyone have any comments about this unit as a phono stage. i am wondering about its dynamics , presence etc and am assuming it is configured for MM. i am not getting reply from the seller so am putting it out to the community
thanks
42 minutes ago, Paul56 said:
Elektro Harmonix 6922 is correct .There are four installed   $200 is for four tubes
Cheers Paul.
It is an obligatory urge for any self proclaimed audiophile to take a peek of the internals, what components used, how's the circuit designed and layed out, the build quality... pretty much like a naked opposite sex.
oh yeah sure we have a whole sub forum just for that. however he obviously feels obliged to atleast warn the unwary... of which there more than likely might be some who dont quite understand the risk involved or what they are actually doing.
Are there any images of the internals of this unit? Not this one in particular but the same model lying around.
I did have some. I'll post them to Lids Lifted if I can find them.
Very standard for equipment to have that warning on the covers.  It's to prevent idiots killing themselves.  You can't  hear, smell or see 240V mains present.
You can hear it and smell it when it's too late though. Luckily, I live to tell the tale.
 - yes I was one of those uneducated fools whose fingers were where they shouldn't have been.
telecine's avatar is my earliest childhood memory :D so I started early hehe
Dont worry,
even a educated idiot like me cope it and have been where you've been.  I recently replaced a faulty PSU on a 3phase machine.  Even thought the 240v 3 phase  was physically disconnected I coped it because a capacitor in the PSU wasn't discharged due to it being faulty...  next time I know better when I see high voltage caps in SMPSU....
Um, there's a big difference between swapping compatible tubes vs incompatible tubes. 12AT7s have different operating parameters to 6922s, you cannot really substitute them. However that does not mean you cannot swap different 6922s or other compatible tube types.
