listenup Posted May 19, 2017 Posted May 19, 2017 Item: Weston Topaz Valve AmplifierLocation: MelbournePrice: $1100.00Item Condition: PerfectReason for selling: Too many ampsPayment Method: Pickup - Cash, Paypal, Bank deposit, COD OnlyExtra Info: Earls Amps really don't need any introduction on Stereonet. They are well built, look great and sound incredible. This Amp is in perfect condition, no marks or scratches. Prefer local pick up, the Amp is heavy (around 20 kg). Paypal add 2.6%. Pictures: 2
listenup Posted May 19, 2017 Author Posted May 19, 2017 Hi, Yes, it is an 8 ohm model. The manual says it is also fine for 6 to 12 ohms too. Cheers
joz Posted May 19, 2017 Posted May 19, 2017 Lovely amp,I'm not looking to buy but for perspective buyers which tubes and how many watts.
Guest Posted May 19, 2017 Posted May 19, 2017 Hi I own the tempest monos earles amps are wonderful GLWTS
listenup Posted May 19, 2017 Author Posted May 19, 2017 Hi, The Amp is rated at 35 watts per channel and the tubes are a mix of EL34's and 6SL7's. Cheers
listenup Posted May 19, 2017 Author Posted May 19, 2017 Hi, I have a buyer in Melbourne and the Amp is to be picked up tomorrow. Thanks for all the messages and offers, it is a terrific Amp and I'm already feeling a bit of regret... Cheers
LunA Posted May 19, 2017 Posted May 19, 2017 Great sounding amp, I have the "Trinity" and love it too!
woogie59 Posted May 19, 2017 Posted May 19, 2017 Yes a bargain. Just received my Topaz from Earle two days ago. Special edition with KT150 valves and many other upgrades. Sounds wonderful. 9
PKay Posted May 19, 2017 Posted May 19, 2017 1 hour ago, woogie59 said: Yes a bargain. Just received my Topaz from Earle two days ago. Special edition with KT150 valves and many other upgrades. Sounds wonderful. Looks fantastic. 2
Chris Daley Posted May 19, 2017 Posted May 19, 2017 Oops would have been interestedSent from my iPhone using Tapatalk
Fec Posted May 20, 2017 Posted May 20, 2017 Yep regret selling my topaz. Truly a fantastic amp. The kids would have learnt not to touch them after a while 1
k2tsui Posted May 20, 2017 Posted May 20, 2017 16 hours ago, woogie59 said: Yes a bargain. Just received my Topaz from Earle two days ago. Special edition with KT150 valves and many other upgrades. Sounds wonderful. Could you share more detail about your amp? what's the upgrade ? very interested!!
woogie59 Posted May 20, 2017 Posted May 20, 2017 No problem. Essentially upgrade from KT120 to KT150 tubes but with the following upgrades. Specifications: Headphone output 6.4mm socket 4 and 8 ohm speaker outputs Upgraded coupling capacitors(mundorf) Upgraded resistors in the bias network Upgraded power supply circuit and capacitors Black chrome(graphite) transformer covers Black stain birdseye maple wood finish plinth I saw a custom job he had done with the black covers and the black stain. It appealed to me as it goes so well with my black equipment. Note, each of the above increases the price, especially the bling, so be prepared.
kelossus Posted May 20, 2017 Posted May 20, 2017 37 minutes ago, woogie59 said: More bling Nice mate, how long did it take for the build.
eman Posted May 20, 2017 Posted May 20, 2017 1 hour ago, woogie59 said: More bling specs on the Bling ? or aren't there any ?
Red MacKay Posted May 20, 2017 Posted May 20, 2017 What recumfryers has Earle used in the Bling machine?
woogie59 Posted May 20, 2017 Posted May 20, 2017 Unit was a bit delayed due to issues outside Earle's control. Build took approx. 8 months from order to receipt but Earle kept me informed all the way. Not sure on the rectifiers used. Specs as per manual. Power Output : 45 watts per channel Freq Response : -3db 10hz.60khz -6db 6hz.100khz Separation : >65db Signal to Noise : >90db A Weighted Signal to Hum : >88db Distortion :<0.05% at 1 watt rms Hum Level : <3.0 millivolt Sensitivity : 700mV Inputs : 4 Speaker output : 4 and 8 ohm(up to 12 ohm is fine)
listenup Posted May 20, 2017 Author Posted May 20, 2017 Hi All, The Topaz has gone to a new home, thanks for all the interest. Cheers
