Luvitloud Posted May 18, 2017 Posted May 18, 2017 Hi I'm trying to setup my Oppo network but I can't get pass the login page I don't know what username and password there asking for I've tried using my email username with my wifi password NOPE Then my MacBook name with its password NOPE Any suggestions Thanks P.S Has Oppo and Netflix had a falling out cause that won't work either Sent from my iPad using Tapatalk
Luvitloud Posted May 18, 2017 Author Posted May 18, 2017 This is the screen I'm stuck on Sent from my iPad using Tapatalk
Guest thathifiguy Posted May 18, 2017 Posted May 18, 2017 Have you tried logging in without a username or password?
Luvitloud Posted May 18, 2017 Author Posted May 18, 2017 Have you tried logging in without a username or password? Tried and failed Comes back with log in eraSent from my iPad using Tapatalk
Guest thathifiguy Posted May 18, 2017 Posted May 18, 2017 Wait, is this to connect to wifi? Or is this to access folders after already connecting to your network?
Kaynin Posted May 18, 2017 Posted May 18, 2017 (edited) It's likely asking the modem/router username and password... ...otherwise your home network sharing details... Edited May 18, 2017 by Kaynin
Luvitloud Posted May 18, 2017 Author Posted May 18, 2017 This to access folders from my MacBook I've already setup the Oppo to my wifi that was easy peasy These are the screens I'm going through Sent from my iPad using Tapatalk
Guest thathifiguy Posted May 18, 2017 Posted May 18, 2017 (edited) 1. In the system preferences of the MacBook, you have allowed for sharing of files via network? 2. Username and password (if required) will be your own username and password (so on my MBP I have my name as Tarkan and my password) not the mac's name. Edited May 18, 2017 by thathifiguy
Kaynin Posted May 18, 2017 Posted May 18, 2017 (edited) Have you turned the "My Network" selection to "ON" in the Set-up menu? P. 44 of the manual covers setting up the media sharing network. Edited May 18, 2017 by Kaynin
Luvitloud Posted May 18, 2017 Author Posted May 18, 2017 It's likely asking the modem/router username and password... ...otherwise your home network sharing details... It's not the modem and it's password tried and failed I've opened up my system preferences then selected the folder sharing and ticked the box for file sharing still no helpSent from my iPad using Tapatalk
Luvitloud Posted May 18, 2017 Author Posted May 18, 2017 Firstly thanks for helping I'm a noob when it comes to computers so your patience is is appreciated Ok here's a photo of my file sharing screen Sent from my iPad using Tapatalk
Guest thathifiguy Posted May 18, 2017 Posted May 18, 2017 Do you have a sign in on the computer itself i.e. when you boot it up after shutting down, do you have a login to open up OSX?
Luvitloud Posted May 18, 2017 Author Posted May 18, 2017 1. In the system preferences of the MacBook, you have allowed for sharing of files via network? 2. Username and password (if required) will be your own username and password (so on my MBP I have my name as Tarkan and my password) not the mac's name. I have different usernames for different sites exactly which username are they asking for my MacBook username is my email And which password the modem,MacBook,iTunes email and this list goes on and onAlso I've tried many combos in regard to username and passwordIf you look at my last photo upload in the top column just under Pauls MacBook Air you will see my computers network access name is Paul.local and I tried this as login name with my modem password,then my MacBook password both failed Sent from my iPad using Tapatalk
Kaynin Posted May 18, 2017 Posted May 18, 2017 Okay, I've never used a Mac so looking in to the computer side of things I'm unlikely to be of any help. I'll mention one observation though, the name of the computer network in your last post is "paul.local" doesn't appear in the previous images of the Oppo - only a folder named "PAUL". Are we talking about the same device/computer?
Luvitloud Posted May 18, 2017 Author Posted May 18, 2017 Do you have a sign in on the computer itself i.e. when you boot it up after shutting down, do you have a login to open up OSX? Yes I do and I've used it with my email as login name FAIL I've used it with my MacBook name FAIL and finally my modem name no luck thereSent from my iPad using Tapatalk
Guest thathifiguy Posted May 18, 2017 Posted May 18, 2017 (edited) Ok, probably the simplest thing to try, have you unplugged all your devices from power for two minutes (including powering off your mac) and switch it back on again? I don't feel as though access to the content would be blocked unless you have created a password to block it. If after power cycling, it is still asking for a login, proceed without entering one and see if that finally gets you over the line. I'm thinking it may be some kind of IP conflict causing it. Edited May 18, 2017 by thathifiguy
Luvitloud Posted May 18, 2017 Author Posted May 18, 2017 @Kaynin your observations in regarding my Oppo file name PAUL and my MacBook name Paul.local had me digging deeper into my MacBook files and I can't find any file named PAUL all my files are my full name all in lower case so I searched through all my smart devices and they are named Pauls MacBook,Pauls ipad and Pauls iphone (yes I'm an apple fan) then I remembered I uploaded the Oppo media centre app the other night onto my ipad so opened that up and saw a file named PAUL. I opened it up and it asked for the same bloody username and password the 105 asked for So that got me thinking that the 105 is picking up the app on my ipad so I removed the app from the ipad turned everything off gave it a minute or two (made a coffee) came back turned it all back on opened up the network screen on the 105 and searched for devices and it found the file named PAUL [emoji36]So I'm really stumped Sent from my iPad using Tapatalk
Kaynin Posted May 18, 2017 Posted May 18, 2017 (edited) 2 hours ago, Luvitloud said: Again, not a Mac user here so apologies if I'm way off. This screenshot shows File Sharing: On, and then there's an Options tab just below it to the right. Click on that and see if you can disable having to enter a password from any device to access file sharing on your Mac. Also consider the Edit tab above the Options tab, see what that is about. Finally, on the face of it, it appears that you may have forgotten/mixed up your log-in details. Can you confirm the correct username/password by manually re-entering what you believe them to be into your Mac? Edited May 18, 2017 by Kaynin
Luvitloud Posted May 18, 2017 Author Posted May 18, 2017 Again, not a Mac user here so apologies if I'm way off. This screenshot shows File Sharing: On, and then there's an Options tab just below it to the right. Click on that and see if you can disable having to enter a password from any device to access file sharing on your Mac. Also consider the Edit tab above the Options tab, see what that is about. Finally, on the face of it, it appears that you may have forgotten/mixed up your log-in details. Can you confirm the correct username/password by manually re-entering what you believe them to be into your Mac? When I click the option tab this is the screenAnd this is the screen when I click edit Also all of my usernames and passwords are basically the same and easy to remember. To open my MacBook is the easiest one of them all and on those times when I forget a password or username the website or device lets you change them with the forgot password option Click on that then they send you an email and bobs ya uncle But no such luck with Oppo. So I've sent Oppo an email asking what there asking for hopefully this will clear things up or I just give up trying Thanks for all your help [emoji106]Sent from my iPad using Tapatalk 1
Kaynin Posted May 18, 2017 Posted May 18, 2017 4 minutes ago, Luvitloud said: When I click the option tab this is the screen And this is the screen when I click edit Also all of my usernames and passwords are basically the same and easy to remember. To open my MacBook is the easiest one of them all and on those times when I forget a password or username the website or device lets you change them with the forgot password option Click on that then they send you an email and bobs ya uncle But no such luck with Oppo. So I've sent Oppo an email asking what there asking for hopefully this will clear things up or I just give up trying Thanks for all your help Sent from my iPad using Tapatalk Good luck, sorry couldn't solve it. Technology is brilliant. When it works...
a.dent Posted May 18, 2017 Posted May 18, 2017 I've got all Mac at home and a 103. I don't think I've ever filled in that username/password bit and I still have access to all my music files from my Mac mini via Ethernet. I'll have a look when I get home and see what's going on. I'm in Perth so you probably won't get a reply until tomorrow.
Luvitloud Posted May 18, 2017 Author Posted May 18, 2017 I'm in Perth also[emoji3]I'm using wifi on the Oppo and MacBook Your help is appreciated [emoji106]Sent from my iPad using Tapatalk
