Item: Pair of Arion HS-500 Mono Block Amplifiers fitted with Duelund VSF capacitor each and upgraded valves.
Item Condition: Excellent
Reason for selling: Now running big valve mono blocks
Price: $3750  $3500, Pick-Up (freight can be arranged at purchaser’s expense)
Payment Method: Cash on Pickup
Extra Info:
The HS-500’s are a Vacuum Tube / Class-D Hybrid Monoblock Power Amplifiers.  Further spec’s below.
I purchased these amps new from Lenehan Audio in February 2014, fitted with VSF Duelund capacitors.  I have since added a matched pair of Cryoset treated Electro Harmonix  6H30Pi EB Gold Pin valves in lieu of the standard valves.
These amps where purchased to replace a highly modified Mingda MC34AB amp and have been used to drive my Lenehan ML2’s. They would have continued to remain in my system, had I not taken up the opportunity to try a pair of 200 watt monster valve monoblock room heaters.
Includes original packing boxes and manuals.
The current replacement price is US$6295 + freight + 10% + other import costs.
Happy to demo in Perth metro area.
Comments from SNA members on HS-500’s - http://www.stereo.net.au/forums/topic/46896-arion-hs-500-amp/
External Review - http://www.enjoythemusic.com/magazine/equipment/1010/arion_audio_rs_500.htm
HS-500 Amplifier Specifications
Rated Power @ 8 Ohms : 500 Watts
Rated Power @ 4 Ohms : 1000 Watts
Sensitivity : 1.8 Vrms
Gain : High gain (approx. 29dB) and low gain (approx. 25dB) settings. Currently set on low gain.
Frequency Response: 20Hz – 20KHz +/-0.5dB
Input Impedance : 200K Ohms
Damping Factor : 900 Ref @ 8 Ohms
Maximum Output Current : 35 Amps
Tube : 6H30
Dimensions : 9.75 in W x 4.75 in H x 14 in D (24.8cm x 12.1cm x 35.6cm)
Weight : 22 Lbs (10kg) each
Pictures:
Edited by mcb
Price now reduced to $3500.
As stated previously, happy to demo within the Perth metro area.
  • 4 weeks later...
