frednork Posted May 6, 2017 Posted May 6, 2017 Item: PS Audio P500 Power Plant AC Regenerator (AC Line Conditioner)Location:MelbPrice: $950Item Condition: goodReason for selling: NLRPayment Method: Pickup - Cash, Paypal, COD OnlyExtra Info: "The PS Audio Power Plants are in the category of AC Line Conditioners or Power Conditioners, but PS Audio calls them AC Regenerators. The reason for this is that conventional line conditioners filter the incoming AC, attempting to remove harmonics and high frequency noise that plague all of our home AC lines. Filters are not perfect, so the noise and harmonics are not totally removed. They also typically do not regulate the voltage, nor do they supply balanced AC. Power Plants do both. The Power Plant converts the incoming AC to DC, then converts this back to AC at whatever frequency (50 Hz or 60 Hz and voltage (110 volts to 125 volts) that you wish. Converting it to DC removes all the noise and harmonics. A DSP chip is used to modulate the DC to not only just garden variety 50 Hz or 60 Hz sine waves, but what they call "MultiWave", which contains a combination of frequencies that benefit various types of equipment." I was using this for my front end only as it is not powerful enough to run large power amps, My impression of what is does is you know when you are listening late at night and your system sounds amazing and then you play it the next day and all the magic is gone. In my system the magic came back with this. Unfortunately my new setup is an all in one box so i cant use it. The current version costs over 4k. lots of info on the web. This is very heavy so preference initially to local buyers. Pictures:
Guest scumbag Posted May 6, 2017 Posted May 6, 2017 A PS Audio Power Plant seems to be end-game as far a clean power seems to go: http://hometheaterhifi.com/volume_11_3/ps-audio-p-500-ac-regenerator-9-2004.html http://www.stereophile.com/news/11628/#b5SZD0BdmvJzBSxm.97 If I had the money I'd think seriously about grabbing this. GLWS.
tellmidd Posted May 6, 2017 Posted May 6, 2017 Nice unit! Might be a silly question but does this power plant accommodate AUS 3 pin plugs?Sent from my iPhone using Tapatalk
frednork Posted May 6, 2017 Author Posted May 6, 2017 7 minutes ago, tellmidd said: Nice unit! Might be a silly question but does this power plant accommodate AUS 3 pin plugs? Sent from my iPhone using Tapatalk This one doesnt 1
