EXPIRED: Ayon Audio Orion Tube Integrated Amplifier
Amplifier was bought in 2012.
It has had seldom use - perhaps 20 hours at most.
1 year warranty on unit and 3 months on tubes.
Output power: 60Wpc pentode, 40Wpc triode
Tube complement: Four KT88, three 12AU7
Frequency response: 27Hz–40kHz +/-0.5 dB
Transformer taps: 4 and 8 ohms
Bandwidth: 15Hz-50kHz
Nominal voltage gain: 40dB
Input sensitivity (full power): 1V
Input impedance: 100k Ohm
S/N ratio: 85dB (2mV)
Dimensions: 18" x 14" x 10"
Weight: 62 lbs.
Photo of rear of unit now attached.
post-152198-0-81645900-1459552702_thumb.
Rounding out the back panel are the aforementioned Direct In/Pre Out jacks and switch, the USB input, and three line-level inputs which were top-notch-quality gold-plated and chassis- mounted. That USB (and associated internal D/A converter), although garnering barely a mention from Ayon in its literature, proved to be quite a right-sounding thing, accepting up to 48kHz/16-bit datastreams. Way over-qualified for the streaming radio I usually fed it, but obviously not suitable for hi-res music files.
From a review I found
  • 7 months later...
 Share
