Ad Details
Price
AUD $750RRP/MSRP
AUD $1,049Product Type
Power ConditionerBrand
iFi AudioModel Name
iFi audio PowerStation 6-Way Power BoardCondition
As New / MintPayment Method
PayPal, Cash, OskoRegion/State
(VIC) Victoria/AustraliaSuburb or Town
officerOriginal Receipt Available
YesShipping & Pickup Options
Auditioning
NoReason for Selling
NLRFurther Information
Purchased in June 2024 from A2A store in Richmond. I have upgraded to isotek sigma and don't have any use of this PC. Used it for 1.5 months at the most before the sigma deal came through and grabbed that. Have the original box and everything.
Please note: Power cable is required for operation
PowerStation
Our audiophile grade extension block will bring super quiet mains power to your system.
Whatever your set-up, digital, analogue or both, the PowerStation will ensure your listening remains interference free.
Ready, steady, go
The PowerStation uses iFi’s Active Noise Cancelation II to ACTIVELY eliminates noise across the frequency range, even across the lower frequencies.
Each outlet has added passive filters to also eradicate noise from the very highest frequencies.
Gives you the earth...
The PowerStation has inbuilt earth/ground and polarity detection.
No earth/ground can lead to annoying buzzes and hums – the scourge of audio.
We’ve added a 4mm banana socket to the PowerStation so a grounding cable can be used to create a ground/earth when one isn’t present.
Bingo, the sound is gone.
…but keeps you grounded
And the PowerStation is smart. The supplementary ground/earth connection will NOT introduce a ground loop EVEN if the system is already earthed.
More than one earth would also create a ground loop leading to more buzzing and humming and we don’t want that.
Fiercely protective
Polarity detection is vital if you don’t want to hamper the quality of your audio mains. With the PowerStation, this is built-in.
And never fear, max. 30,000A @ 1,000V/10uS surge protection is also here. If it detects a power surge or a mains short, the PowerStation will shut down, protecting your downstream equipment from peril.
Noise reduction>40dB (>100x)
Surge Protectionmax. 30,000A @ 1,000V/10uS
Operating Voltage90V - 265V
Dimensions478(l) x 96(w) x 76(h) mm
Weight1.98kg (4.37lbs)
View All Ads Combine & Save - Other Ads from coffee25
