Ad Details
Price
AUD $7,500RRP/MSRP
AUD $13,995Product Type
Power RegeneratorBrand
PS AudioModel Name
DirectStream Power Plant 15Condition
As New / MintPayment Method
PayPal, EFT, Cash on PickupRegion/State
(VIC) Victoria/AustraliaSuburb or Town
CaulfieldOriginal Receipt Available
NoShipping & Pickup Options
Auditioning
NoReason for Selling
No Reason EnteredFurther Information
Description
The DirectStream P15 Power Plant is the gold standard for safety, reliability, and high-performance AC power regeneration. The P15 improves micro and macro dynamics, audio purity, instrumental separation, soundstage width and depth, and lowers background noise for any connected equipment. From medium to large power amplifiers to the smallest pieces of source equipment, the P15 will work magic on your system’s performance. Don’t starve your music or risk damaging your equipment. A P15 gives you greatly improved performance and safety from just plugging into the wall socket and far better dynamics, bass and a much bigger, open soundstage than any power conditioner on the market.
Design
The P15 features an ultra-low impedance analog power amplifier, FPGA based sine wave generator based on pure, clean, analog DSD (PCM), 10 outlets (US version) across 5 separate regenerated zones, and 1/4″ thick copper busbars that deliver regenerated power to each receptacle. Through regeneration, the P15 creates a completely new AC waveform that adds missing energy back onto the power line to correct for serious issues.
Application
With a maximum output of 1500 watts, the P15 regenerates steady, regulated, pure AC that is unaffected by your equipment’s demands for power. Powering your system from the outlets of the P15 will reveal new voices, new harmonics, and a renewed sense of musicality. As the gold standard for safety, reliability, and high-performace AC power regeneration, the P15 will ensure you receive the same great performance every time you listen and provide a firm foundation for your system.
Overview
The DirectStream Power Plant 15 is the next generation of AC power regeneration. It has 5 separate regenerated zones, buss bar delivery system, and 1500 watts of pure regenerated power. From medium to large power amplifiers to the smallest pieces of source equipment, the P15 will work magic on your system’s performance. Expect far better micro and macro dynamics as well as a cleaner, lower noise background. Power regeneration uses active components, like those found in large, powerful audio amplifiers, to rebuild the AC power and produce clean, clear, distortion-free, regulated AC to the equipment. The results are dramatic: unrestrained dynamics even under the loudest passages, an open, wide soundstage that does not collapse with volume and a naturalness to the music that is remarkable. The 7-inch, full color display on the front panel of the P15 allows you to measure distortion, both incoming and outgoing, improvement levels, and power consumption. You can also adjust your settings, such as the turn on/off sequence and the output voltage, as well as turn individual zones on or off, and measure the power quality with either the built-in oscilloscope or the THD analyzer.
Output
The P15 takes in your home’s noisy, distorted, and unregulated AC and outputs pure and perfect power that dramatically enhances sound quality. It does this by rebuilding the AC, lowering output impedance, and regulating the voltage. Low output impedance is critical to maintaining a dynamic presentation. Powering equipment through a passive power conditioner only worsens the problem and should be avoided. The Power Plant, on the other hand, has such low output impedance (0.008Ω vs. typical 0.4Ω) that even the hungriest of amplifiers won’t be starved for clean AC power. When your amp is asked to produce loud orchestral levels, you want to make sure it has all the power it needs and only a Power Plant provides a constant output regardless of the dynamic demands of equipment or your neighbors. Power Plants also generate new waveforms that enhance the capabilities of your equipment. MultiWave extends the peak charging time of the sine wave so connected equipment has more energy storage and less power supply ripple. The results are dramatic: a bigger more musically accurate soundstage than with a simple sine wave.
Features:
• Built in Boulder
• 1500 VA Output
• 3x Lower Impedence Than P10 Power Plant
• 10x Outlets US
• 15Amp AC Input US
• 120 Volt Regulated US
• Range 95 – 145 VAC US
• 9x EU/AU/GR/UK Outlets
• 10Amp AC Input EU/AU/GR/UK
• 230 Volt Regulated EU/AU/GR/UK
• Range 200 –285VAC EU/AU/GR/UK
• 100% Regenerated AC
• Passively Cooled
• Pure Sine Wave
• Multiwave
• Integrated Oscilloscope
• THD Meter
• Improvement Meter
• Power Meter
• Control Over the LAN
• Adjutable Output Voltage
• Color Touchscreen
• Field Upgradeable
For Sale
Rockna Wavedream Edition SE Digital Analog Converter (DAC)
By logicaldisconnect
10 days and 11 hours
- 291
- 1
- 3
- 0
AUD $6,300 -
For Sale
For Sale
