EXPIRED For Sale iFi Audio iFi audio PowerStation 6-Way Power Board Power Conditioner
AUD $800
2 Images
Ad Details
Price
AUD $800
RRP/MSRP
AUD $1,049
Product Type
Power Conditioner
Brand
iFi Audio
Model Name
As New / Mint
Payment Method
PayPal, Cash, Osko
Region/State
(VIC) Victoria/Australia
Suburb or Town
officer
Original Receipt Available
 Yes
Shipping & Pickup Options
Shipping:  Available
Pickup: Available
Auditioning
No
Reason for Selling
NLR
Further Information
Purchased in June 2024 from A2A store in Richmond. I have upgraded to isotek sigma and don't have any use of this PC. Used it for 1.5 months at the most before the sigma deal came through and grabbed that. Have the original box and everything.
Please note: Power cable is required for operation
PowerStation
Our audiophile grade extension block will bring super quiet mains power to your system.
Whatever your set-up, digital, analogue or both, the PowerStation will ensure your listening remains interference free.
Ready, steady, go
The PowerStation uses iFi’s Active Noise Cancelation II to ACTIVELY eliminates noise across the frequency range, even across the lower frequencies.
Each outlet has added passive filters to also eradicate noise from the very highest frequencies.
Gives you the earth...
The PowerStation has inbuilt earth/ground and polarity detection.
No earth/ground can lead to annoying buzzes and hums – the scourge of audio.
We’ve added a 4mm banana socket to the PowerStation so a grounding cable can be used to create a ground/earth when one isn’t present.
Bingo, the sound is gone.
…but keeps you grounded
And the PowerStation is smart. The supplementary ground/earth connection will NOT introduce a ground loop EVEN if the system is already earthed.
More than one earth would also create a ground loop leading to more buzzing and humming and we don’t want that.
Fiercely protective
Polarity detection is vital if you don’t want to hamper the quality of your audio mains. With the PowerStation, this is built-in.
And never fear, max. 30,000A @ 1,000V/10uS surge protection is also here. If it detects a power surge or a mains short, the PowerStation will shut down, protecting your downstream equipment from peril.
Noise reduction>40dB (>100x)
Surge Protectionmax. 30,000A @ 1,000V/10uS
Operating Voltage90V - 265V
Dimensions478(l) x 96(w) x 76(h) mm
Weight1.98kg (4.37lbs)
ELECTRICAL DISCLAIMER
View All Ads Combine & Save - Other Ads from coffee25
RockRolley
Hi,
To be up front, I'm not ready to get a power solution, but am considering it for the future, and I like Ifi products. Question: can you run a regular power board from these units and distribute the quality power to other components? I have probably around ten components in my main system.
6 hours ago, RockRolley said:
Hi,
Yes you can. I did the same - ran a cheap white board from Bunnings . Also checked that with my emi tester and the positive effects were passed on to the white board. The only thing to consider is the total amp should not get above 10amp , as all single Aussie wall sockets are 10amp rated.
RockRolley
Awesome!
Noted-excellent point. Thanks
