Yamaha TW-E7B True Sound & TW-ES5A Sports Buds Announced
The TW-E7B and TW-ES5A offer the company's True Sound and Listening Care technologies. In addition, E7B adds Yamaha's special active noise cancellation, while the ES5A boasts IPX7 water and sweat resistance, as well as sporty silicone fins to keep the buds in place while you're doing fitness stuff.
Just as in the recently-announced E5B, Yamaha states that its True Sound tech combines acoustic and digital technologies to render the music “as the artist intended”. Meanwhile. Listening Care balances the frequency extremes during low-volume listening, meaning you don't have to go loud not to miss out on those bits. In the long run, the aim is that preventing unnecessary volume will help preserve your hearing.
While the streamlined ES5A has the standard Listening Care, the E7B boasts Listening Care – Advanced. This is said to factor in the content volume (such as dynamic range and recording levels) and background noise to optimise the sound at any level, hopefully further preventing you from nudging the volume upwards.
Moreover, Yamaha asserts that its noise cancellation is unique thanks to the company's algorithm. Where some solutions will affect the music as well as noise, Yamaha says that its ANC system analyses the signal received from the internal mic and the playback music signal, calculating and filtering the noise components out to leave the music signal untouched. The result is that it doesn't have to compensate via EQ correction as with most other ANC systems.
The E7B is loaded with 10mm drivers with the housing features acoustic holes to control the airflow and, says Yamaha, maximise performance. Further enhancement comes in the shape of an app-based Listening Optimiser function that analyses the shape of the inside of your ear and adjusts the sound to compensate.
Both sets of wireless buds benefit from Qualcomm Clear Voice Capture (cVc) and TrueWireless Mirroring; the latter does away with the old 'Slave and Master' system and instead enables independent transmission from music sources to each earbud. Also, low-latency Gaming Mode makes playing games or watching videos much better.
The battery stamina is six hours for the E7B buds, plus another 16 from the charging case. As the ES5A doesn't have to power ANC (and should be fitter), you get nine hours from the buds and 25 from the case.
The Yamaha TW-ES5A ($229 RRP) and TW-E7B ($299 RRP) will be available mid-June.
Visit Yamaha for more information
Posted in:Headphones
Tags: yamaha
