Monitor Audio Launches Sixth Generation Bronze Loudspeaker Range
Posted on 28th May, 2020
Following their debut at this year's Bristol Hi-Fi Show in the UK, Interdyn, Monitor Audio's Australian distributor, Interdyn, has released pricing on the sixth generation Bronze loudspeaker family.
Monitor Audio Bronze 6G
Monitor Audio has totally redesigned and re-specced the rear-ported Bronze speaker line - not only have Bronze loudspeakers received a complete upgrade in both sound and build quality, but even the cabinet sizes have changed.
The 6th Gen Bronze Series features a new Uniform Dispersion Waveguide to partner with Monitor Audio’s signature C-CAM Gold Dome Tweeter. We are told that this results in even sound dispersion, improved time alignment and wider directivity. Not only does the acoustically transparent hexagonal dispersion patterns on the tweeter covers lend the Bronze range some premium cachet, but it also allows the light to glint off those distinctive gold tweeter domes.
The new Bronze range also sees Monitor Audio adding Dolby Atmos modules for the first time. The new Atmos topper is fitted with an upward-firing 4-inch driver, and the units are designed to match the Bronze 50 standmounter and Bronze 200 floorstander cabinet tops.  On the subject of cabinets, the units are constructed from braced 15mm MDF. They are available in Black (black vinyl and satin dark grey front baffle), White (white vinyl and satin light grey front baffle), Walnut (walnut wood vinyl and satin dark grey front baffle), and Urban Grey (grey wood vinyl and satin light grey front baffle).
All but the two floorstanders, the Bronze 200 and 500, are 2-way designs whereas those are 2.5-way and feature a pair of HiVe II ports. All the speakers (except the woofer, naturally) have a claimed upper in-room frequency range of 30 kHz. The low-end varies depending on cabinet size from 40 Hz for the 50, to 32 Hz for the 500.
Gold-plated terminals and Pureflow silver-plated oxygen-free copper internal cabling offer secure cable connectivity. The crossovers utilise premium grade, bespoke polyester film and electrolytic capacitors, air-core and low-loss laminated steel-core inductors for maximum signal transfer and reduced distortion, according to Monitor Audio.
The new range will be available from mid-June but can be pre-ordered now. Australian pricing is as follows:
  • Monitor Audio Bronze 50 Bookshelf Speakers
  • Available in: Black, White, Walnut & Urban Grey - RRP: $699.00 (pair)
  • Monitor Audio Bronze 100 Bookshelf Speakers
  • Available in: Black, White, Walnut & Urban Grey - ​RRP: $849.00 (pair)
  • Monitor Audio Bronze 200 Floorstanding Speakers
  • Available in: Black, White & Walnut - RRP: $1,549.00 (pair)
  • Monitor Audio Bronze 500 Floorstanding Speakers
  • Available in: Black, White & Walnut - ​RRP: $1,999.00 (pair)
  • Monitor Audio Bronze C150 Centre Speaker
  • Available in: Black, White & Walnut - ​RRP: $499.00
  • Monitor Audio Bronze W10 Subwoofer
  • Available in: Black, White & Walnut - ​RRP: $1,499.00
  • Monitor Audio Bronze AMS Dolby Atmos Enabled Speakers
  • Available in: Black, White - RRP: $799.00 (Pair)
  • Monitor Audio Bronze FX Surround Speaker
  • Available in: Black, White - ​RRP: $799.00 (Pair)
For more information, check out Monitor Audio.
    Posted in:Hi-Fi Home Theatre
    Tags: interdyn  monitor audio  denco
    00005255
