Fyne Audio Releases Custom Installation Speaker Range
Posted on 13th December, 2019
Scottish speaker brand, Fyne Audio, has been making waves since it first appeared on the scene in 2017, and rightly so. However, its latest coup is designed to be more heard and less seen. Launching its first range of residential custom install loudspeakers with two ranges and five models, Fyne says the new models draw upon the technology and voicing of Fyne's award-winning F300 and F500 traditional loudspeakers.
FA300iC Series
The FA300iC series comes in compact 6-inch (FA301iC - $275.00 each RRP) and more potent 8-inch (FA302iC - $375.00 each RRP) flavours. The multi-fibre bass / mid cones are terminated with Fyne's signature FyneFluteTM roll surround that promises improved low-frequency performance. Additionally, the FA300's 25mm polyester dome tweeter is mounted on an adjustable pod offering up to 20 degrees of tilt so it can be focused on the key listening position.
The FA300iC models boast 100W @ 89dB/W and 120W @ 90dB/W power handling for the 6-inch and 8-inch models respectively. All models are supplied with round low profile magnetic grilles that are fully paintable to match the home décor. Each grille is supplied with a scrim cloth to further conceal the drivers. A square grille is offered as an optional extra on both models.
FA500iC Series
The FA500iC series is Fyne's premium custom install range. Here you get the company's renowned IsoFlare technology and the high-frequency driver sophistication of the F500 series. Furthermore, this range features a crossover tuned to get the very best from a flush-mount infinite baffle position. Again, you get a choice of 6-inch (FA501iC - $395.00 each RRP) and 8-inch (FA502iC - $525.00 each RRP) driver, plus an 8-inch version with the driver set at 15 degrees (FA502iC LCR - $595.00 each RRP). The latter could be perfect for a home theatre installation, for instance.
There's an increase in power handling in this range, too, with up to 150W and 91dB efficiency. Equally suitable for positioning in-ceiling or in-wall thanks to shallow mounting depths and easy to install clamps, all models offer sprung binding post terminals to further ease installation. The FA501iC and FA502iC are supplied with both round and square, low profile magnetic-mounted paintable grilles, while the FA502iC LCR is provided with round only.
Finally, all models in Fyne's new home install ranges are supplied complete with cut-out template, scrim backed grilles and simple dog leg clamps to secure into plasterboard wall and ceilings.
Both ranges are available now. For more information, visit Fyne Audio.
    Marc Rushton's avatar
    Marc Rushton
    StereoNET’s Founder and Publisher, born in UK and raised on British Hi-Fi before moving to Australia where he worked as an Engineer in both the audio and mechanical fields.
    Posted in:Home Theatre Integration
    Tags: fyneaudio  hificollective
    Get the latest.
    Sign up to discover the best news and review from StereoNET in our FREE Newsletter.
    Commercial Interests Disclosure
    In accordance with the ACCC Guidelines for online Reviews, StereoNET advises readers that we may have commercial marketing relationships with some of the brands featured within our reviews and editorial. These relationships may include display advertising and other promotions, but do not in any way influence the outcome of our independent product reviews.
    THE LATEST
    00003000
