Audio Pro A15 Portable Speaker Adds Multiroom Music Outdoors
Posted on 28th March, 2022
Audio Pro's latest portable speaker, the A15, brings multiroom to your garden.
The Audio Pro A15 portable wireless speaker sports a typically Swedish minimalist sense of style while boasting an IPX2 rating which means that it will survive a British spring shower. Additionally, a carry handle is formed by the A15's rear bass port.
Audio Pro A15
The Audio Pro A15 is wrapped in the same fabric as some of the brand's other speakers, including the A26 and A36, which it will also play nicely with over wi-fi to create a multi-room system. Moreover, thanks to AirPlay 2, Google Cast, and Audio Pro's own multi-room system, you can also add compatible speakers from other brands!
Audio Pro A15
Naturally, you can play the same music throughout your house or have a chill-out zone indoors while the party rages outside. The A15's battery is good for 11 hours at half volume level, whilst cranking it up to full volume will return you just over 8 hours of play time, says Audio Pro.
Audio Pro A15
The Audio Pro A15 wireless networked portable speaker will be available in May 2022 and will sell in Australia for $579 RRP.
Visit Audio Pro for more information
    Posted in:Lifestyle
    Tags: audiopro  aqipa  audio pro
    00000882
